Old 03-11-2008, 10:11 AM
Juggernaut's Avatar
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Default T5 Clutch Adjustment
I recently got my Cobra on the road & noticed the clutch slips in second & third gear when I get on it a little.
I'm using a T5 with a CNC hydraulic push type slave cylinder & Tilton master cylinder/pedals. The clutch disc/pressure plate are stock components, the throw-out bearing is non-hydraulic.
My question is should I adjust that slip out now or drive it easy for a few hundred miles then see how it is? Is there a "wear in" period on new clutch/pressure plates?
Thanks for the help.
Randy
Juggernaut
Old 03-11-2008, 10:54 AM
There is a break in period on some clutches...
As for this one, I'd check to make sure it's adjusted correctly.
Old 05-18-2008, 10:10 PM
Cobra Make, Engine: KMP 498
How do you adjust a hyd clutch? Seems like mine with 400 miles now it does not go in far enough, already re-bleed the thing.
Sanded Aluminum Finish? Because I Can!
Old 05-19-2008, 04:55 AM
What exactly are the symptoms?
Old 05-19-2008, 06:50 AM
It is not going in far enough, it just started yesterday. So you can't put it in gear. It has to be the slave cyl. adjustment?
Old 05-19-2008, 07:06 AM
When you push the clutch in, it's not fully engaging the clutch? Sounds like air in the line.
