05-09-2008, 05:54 PM
Az
Who sells Hydraulic clutch setups
I need a Hyd clutch setup for my Mav project. I had one lead but they said they are out 90 days due supplier issue.
Any leads are appreaciated.
tim
05-09-2008, 06:55 PM
Cobra Make, Engine: BDR 930, 427 Windsor T56
speedwaymotors.com has some options.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
05-09-2008, 09:18 PM
Cobra Make, Engine: FFR-4000 under construction
Summit Racing sells the McLeod set ups.
Don
05-09-2008, 09:43 PM
Hydraulic throw-out bearing, or clutch slave cylinder?
Phil
http://www.uniquecobra.com/
05-09-2008, 10:09 PM
Cobra Make, Engine: superformance/427 fe ford
see or talk to bruce at modern driveline. he used to be in san jose ca. but moved to idaho. i think he still has a 408 area code. anyway, that is the man to talk to.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
05-09-2008, 11:33 PM
If you need one I have a spare, brand new, McLeod Hydraulic throughout bearing for a TKO. PM if you are interested.
Ed
05-10-2008, 04:38 AM
Az
Im sorry, Im looking for a Master/slave setup.
Thanks for the replies.
Tim
05-10-2008, 07:23 AM
You can piece that together pretty easily. Try a Wilwood master cylinder and clutch slave cylinder (Summit). You just need to determine whether you want a push or pull slave cylinder.
Phil
05-10-2008, 11:35 AM
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
Be aware that Wilwood has had a few problems recently with their slave cylinders. The rod had been coming unscrewed from the piston on the slave cylinder.
I am aware of five or six Lone Star owners that have experienced the issue in the past few months. Wilwood is aware of the problem and told me they were looking into it about a month ago. We sent them pictures of our installations and they told us they appeared to be installed correctly.
I have a Wilwood slave cylinder and have replaced one (under warranty) and repaired one myself in less than 2,000 miles.
Jody
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
05-10-2008, 03:38 PM
Az
What size Master and slave should i get. I have a G-force T-5 with a Centerforce DFX clutch and Aluminum flywheel and lakewood bell. This a 94-95 bellhousing, they are a tad deeper than the 86-93 bells.
05-10-2008, 04:24 PM
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
The Wilwood reverse pull slave is, I think .78 dia. I use a Wilwood 1" master cylinder, clutch is a Centerforce dual friction. The clutch is easy to depress, and I've had no problems in the three years I've had it. Wilwood recommended a
.75 master, but that was way to easy, giving very little resistance and little feel in the pedal. The 1" master works much better. The Slave connects to a OEM clutch arm, and uses a Centerforce stock replacement throwout bearing.
Some external slave cylinders fail because of the mount. If they are solidly mounted, the piston rod can be side loaded in operation and wear the seals, causing leakage.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
05-10-2008, 07:18 PM
Cobra Make, Engine: Backdraft #520, 302 FORD racing Z50Z,t-56,391 posi
I've used both McLeod and Ram,I like the Ram set-up,it has a better feel and it takes less movement and pressure,I used a 1" wildwood master with the Ram,and a 3/4"with the McLeod.
05-10-2008, 07:22 PM
I've used both McLeod and Ram slaves,both internal,1"with the Ram and 3/4 with the Mcleod,the ram gave a better feel,and was easier to use.
