Old 07-20-2008, 03:30 AM
AC-460's Avatar
Default Shifter positions TKO600
Just putting a TKO600 behind the 545BB in the cobra. I need to know the measurements of the shifter positions if anyone can help me out!!! I've had a couple of conflicting measurements don't know if I need to go midshift or not!!
Old 07-20-2008, 06:26 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
You can bolt a plate to the shifter coming out of the trans and direct it anywhere you want.
I moved mine five inches forward.
I think you can download the trans specs off the net.
BTW, it doesn't like to shift gears above 7K.
Old 07-20-2008, 08:20 PM
AC-460's Avatar
can anyone give me a measurement from the front of the bell to the centre of the midshift on TKO600
Old 07-21-2008, 05:26 PM
eschaider's Avatar
If you use a Quicktime bellhousing and a TKO the bellhousing depth is 7.05 inches deep. I have attached a Tremec document with dimensions to the different shifter positions they support.
Take a good look at the Quicktime bellhousings - I think you'll be impressed. I have a lakewood and it is significantly heavier.
Good luck on your build.
Ed
Sorry for the false alarm. The website places a 39KB limit on pdf uploads and the tremec document exceeds the limit. You can still get it by going to the Tremec website and downloading from their documentation page.
