SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 05-04-2009, 03:08 AM
Cobra Make, Engine: Cobra FF5/BBM 482
Default t-56 adapt
does anyone make an adapt for a t-56 gm trans to an fe
Old 05-04-2009, 03:12 AM
Yes, Quicktime makes two of them...one for a Ford T-56 to FE, and one for a Viper T-56 to an FE.
If you give me some details, I'll be happy to provide you with information and pricing.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 05-04-2009, 04:18 AM
joyridin''s Avatar
There are several companies that make an adapter plate that adapts a T56 to the factory bellhousing or an aftermarket bellhousing. I am currently using one of these and it works well. The only catch is the trans has to be from a LS1. If not, you will have to change the input shaft.
Old 05-04-2009, 04:19 AM
Hi feadam,
I make an adapter that will bolt an LS T-56 to a stock bellhousing. If you have a late LT T-56 I have a LS input that will work too..
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 05-04-2009, 06:49 AM
joyridin''s Avatar
Mike, What do you do with the speedometer? I was looking at a Cable-X or an electronic Cobra speedo from Classic Gauges. How do you handle the adaption?
Old 05-04-2009, 11:50 AM
Question You have a private e-mail
Feadam You have private e-mail. Rick L.
Old 05-04-2009, 01:15 PM
didnt get email
