Old 05-21-2009, 01:44 PM
Default reverse autometer/Tremec
Once my body is back from the paiter I'll be doing the final assembly on my Unique Cobra. Do I need an adpter for my reverse autometer speedometer connected to my tremec TKO600.? If so where can I purchse it. Thanks
Old 05-22-2009, 02:46 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
No adapter is required. Before you hook the speedo cable to the tranny, bolt the speedo in place, hook the cable to it and make sure it spins free. There is a small drive shaft between the reverser and the Autometer speedo that had to be "adjusted" with a grinder on mine to keep it from binding. If it binds you get to buy another cable.
Bill Stradtner
Old 05-22-2009, 06:19 AM
damdfw's Avatar
Cobra Make, Engine: CSX 4973
Default You need a reverse gear
You will need a reverse gear for your autometer reverse speedometer if you don't have one.
Like this one http://www.tristatemotorsports.com/D...ct.cfm?ID=8150
Old 05-22-2009, 08:04 AM
Xavier's Avatar
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
I will sell you mine for $15 chees head. PM me if you are interested. You will need the reversing gear...I have the exact one damdfw posted in the link.
Old 05-23-2009, 03:15 PM
Seasoned Member
My Autometer speedo on my Unique had a right-angle reverser as part of the package. Again, try it before you drive it. When you tighten the reverser down it can bind against the speedo. It only takes a minute to try it but a week to get a new cable for your T600.
Bill Stradtner
Old 05-25-2009, 08:17 AM
Thanks,all. got the adapter on order. Appreciate all the help
cheese
