Old 08-16-2009, 09:26 PM
lal Naja's Avatar
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Default Super T -10. Where is 1,2,3 & 4th.
I'm sure there is a guru that can answer this question.
On the drivers side of the Super T-10 transmission there are three shifter tabs. The one rearmost is Reverse. The two others tabs standing vertical on the transmission operate 1st. 2nd. 3rd. & 4th. I'm trying to clarify if my understanding is correct.
The tab closest the front when moved forward is 4th. gear, moved back past neutral is 3rd. gear. Correct?
The next tab rearward is 1st. and forward past the neutral is 2nd. Correct.
I look forward to your comments,
Arthur
Old 08-16-2009, 09:48 PM
Arthur, This might help.
http://www.richmondgear.com/07pdfs/RG25.pdf
Terry
Old 08-16-2009, 11:21 PM
lal Naja's Avatar
Terry
Thanks, this is good info and I will keep it filed. Still does not clear up my question on what gear you are in when the tabs move front to back.
Old 08-17-2009, 04:11 AM
Makes sense....
First shifter cam is 4th (forward) & 3rd.
Second is 2nd (forward) and 1st.
Third is reverse.
That's the way it is on a Toploader.
Or wait.....is the middle one on a Toploader reverse? I can't remember....been awhile since I've been in one.
The front one is for sure 3rd/4th.
You can take a little wrench and move the shifter lugs each way. The one towards the rear of the transmission that clicks when you go each way would be 1st/2nd. The reverse gear actually slides back and forth on a shaft with no synchronizers, so it should be easy to feel it.
Old 08-17-2009, 05:55 AM
Check out this picture.
http://www.carcraft.com/techarticles.../photo_05.html
Terry
Old 08-17-2009, 07:19 AM
correct, same as a muncie.
Old 08-17-2009, 03:43 PM
lal Naja's Avatar
Thanks everyone, seems like we have a consensus.
