Turn Ten Racing, Inc. and D&D Cobra of Quebec
Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Turn Ten Racing and D&D Cobra
User Name
Password
Club Cobra Home Register FAQ Members List Calendar Today's Posts
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 03-26-2008, 06:50 AM
ddcobra's Avatar
Thumbs up best price ever 18995$ complet kit full roller!
This sale is for a limited time only so if you want to save big now is the time.Our dollar went up so i save you save!!!!!
The EVO5 Complete kit gives you everything you need to build your car
Frame:
Complete jig-welded original style 4” round tube frame. Includes all mounts ready to accept small or big block Ford .
Comes powdercoated in gloss black and silver suspensions parts
Includes three point SS roll bar
Includes mounts to accept passenger side roll bar.
Body:***INSTALL***
Hand laid 1/4” laminate composite body and panels made with vinylester resin. COMPLET BODY DOOR,TRUNK,HOOD WITH HINGES.
Complete Front Suspension:***INSTALL***
Unequal length a-arm control arms with QA1 coil-over shock suspension.
500lb. black powdercoated performance springs
Adjustable upper control arms with ball joints
Lower tubular control arms with ball joints
Complete Rear Suspension:***INSTALL***
Ford Racing 8.8” posi solid axle rear end with QA1 coil-over and Ford 8.8” 3.08 gears.D&D custom tubular rear lower control arms, w/ rodend bushings and fasteners
350lb. black powdercoated performance springs
Complete Front/Rear Brake Kit:***INSTALL***
S/N 95 style spindles and spindle adapter bracket
Front Brakes, Ford 11” front rotors w/calipers, brake pads
Rear Brakes, Ford 10.5” rear rotors w/calipers, brake pads, slider and caliper axle mount brackets.
Russell stainless braided brake line, front and rear w/mount clips, banjo bolts and brake line mounting fasteners
Pre-flared 3/16” brake line and brake line T-adapter
Lokar emergency brake handle, fasteners and cable
Complete Steering System:***INSTALL***
15:1 Manual steering rack w/inner and outer tie rod ends
Polyurethane steering rack bushings
Steering rack shaft adapter 9/16-26 spline
Silver painted lower steering shaft (fully welded u-joints)
15” Vintage wood and aluminum steering wheel
Complete Fuel System/Parts:
Aluminium fuel tank
3/8 Fuel lines, connectors and filter
140GPH black fuel pump
Cooling System/Parts:
16''Electric cooling fan
28''x19''Aluminum radiator
Engine Accessories/Side Exhaust/Mounts:
Engine/Transmission mounts (select 302/351 or 4.6L, or 390/427/428, or 429/460)
Exhaust and headers,(select 302/351 or 4.6L, or 390/427/428, or 429/460),
Gauges and Dash and Electrical Assembly:
427 style aluminum dashboard
Padded dash cover, black vinyl
EZ wiring harness
headlight switch, 3-position turn signal switch
Dash indicators, Red, Green, Blue dash lights
Complete set of 7 Autometer cobra gauges, w/connectors, terminals and installation kit. Includes the following gauges:
Speedometer
Tachometer
Oil Pressure Gauge
Water Temperature Gauge
Fuel Level Gauge
Voltmeter
Oil Temperature Gauge
Complete Interior Accessories:
Authentic 427 roadster seats, black vinyl w/fasteners
5-point harnesses. 3” wide driver and passenger, frame mounted
Complete cockpit carpet set, black all-weather
Lokar Emergency brake boot, black vinyl
Authentic interior rear view mirror w/fasteners
Original style door latches,
Authentic 14” wood and aluminum steering wheel
Exterior Accessories and Lighting:
Wiper kit
Authentic Chrome-on-Brass vintage windscreen, tinted with side bars and fasteners. DOT safety glass compliant
Authentic 427 three-lock set including T-trunk handle, L-shaped hood handles, cam wedges
Authentic 3.5” gas cap, polished cast aluminum
side louvers.
cobra badging nose and tail
Original style headlamp assemblies, including buckets,headlamps, trim rings, and fasteners (DOT approved).
Original style British front amber turn signals, and red rear tail-lights
All lighting is DOT approved.
Complete tilton Pedal Box and Components:
Wilwood triple master cylinders
2 x 5/8 Master Cylinders
1 x 3/4 Master Cylinder
Price: 18995.00$ CAN.
Thanks Don.
Old 03-26-2008, 12:53 PM
joey_hv's Avatar
Cobra Make & Engine: Joey Manufacturing Inc.
Send a message via Yahoo to joey_hv
Default nice...
that is like..18 and a half thousand US dollars. smoking deal!
"Me fodder was King Neptune, me mudder was a mermaid. I was born on the crest of a wave and rocked in the cradle of the deep. Me hair is like hemp, me arms are like spars. When I spits, I spits tar. I'm hard, I am, I is, I are. "
Old 03-26-2008, 03:32 PM
Ital-cobra's Avatar
I contributed to CC in 2006
Cobra Make & Engine: Emerson cobra, 460 550HP
Don, I've seen your work that is a GREAT deal....WOW
The desire for imaginary benefits often involves the loss of present day blessings.
Old 04-07-2008, 05:57 PM
ddcobra's Avatar
Wink
This sale is good only for april!
Thanks Don,
Old 04-07-2008, 07:34 PM
CHANMADD's Avatar
Cobra Make & Engine: 1989 KCC from South Africa Right Hand Drive
Default webadress
How do I get to your Website??
Old 04-07-2008, 09:43 PM
Cobra Make & Engine: Cobra International body Waltech frame
Actually.....the USD has dropped from the CDN D
MV
"A company that makes nothing but money is a poor company" - Henry Ford
Old 04-08-2008, 05:14 AM
Clois Harlan's Avatar
I have in the past contributed to CC
Cobra Make & Engine: 66 COBRA FE 427 /4SP. (HCS Coupe w/ 408 Stroker and TKO 600 -sold)
Hey Donald that sounds like a super deal for anyone wanting to do a little work and save a few bucks!
Clois
"Let's roll"
"Be part of Something Good
Old 04-08-2008, 06:08 AM
ddcobra's Avatar
www.ddcobra.com
You will not found a lot on it, because i sell in europe and i dont want to make any confusions. You will find every thing you need on our forum on cc
Thanks Don,
Old 04-22-2008, 03:41 PM
ddcobra's Avatar
This sale is good only for 8 more days!!!
Thanks Don,
Old 04-23-2008, 08:01 AM
danc30's Avatar
Cobra Make & Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Today's rate is:
Live rates at 2008.04.23 15:00:07 UTC
18,995.00 CAD = 18,641.15 USD
Canada Dollars United States Dollars
1 CAD = 0.981371 USD 1 USD = 1.01898 CAD
Old 04-24-2008, 03:17 PM
ddcobra's Avatar
Thumbs up
This sale is good only for 6 more days!!!
Thanks Don,
Old 04-24-2008, 03:26 PM
CHANMADD's Avatar
How do I get any information from your Website???. No links work???
Old 04-24-2008, 03:40 PM
ddcobra's Avatar
you can go on www.ddcobra.com or go on the forum Turn Ten Racing and D&D Cobra http://www.clubcobra.com/forums/turn-ten-racing-d-d-cobra/ you will find all the info you want or send me a pm i will call you!
Thanks Don,
Old 04-29-2008, 06:25 AM
ddcobra's Avatar
This sale is good only for 2 more days!!!
Thanks Don,
Old 12-30-2009, 12:55 PM
Salut Donald..
C'est un bon deal ca..
beubye
