Go Back   Club Cobra > Club Forums > VA / NC Cobra Club
Old 12-01-2010, 06:32 PM
Default Setting up webers
Hi,
Anyone know of someone in the Greensboro NC area that can set up a webers carb system.
Phil
Old 12-01-2010, 07:06 PM
Stentor's Avatar
I don't know of anybody in Greensboro. However, Dennis Olthoff (outside of Charlotte) is good. He has done a lot of work on my car (including tuning of my 58 mm IDAs). He did a nice job of dialing in my IDA carbs.
http://www.olthoffracing.com/
Good luck.
Old 12-01-2010, 08:55 PM
dlampe's Avatar
If you want to do it yourself, there is enough of us here to help talk you through the process. Just tell us about your set up and how things are behaving now.
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 12-02-2010, 07:05 PM
Default Weber setup
Hi, On right side of engine carbs vacuum is up and heat temp on headers is good. On left side of engine vacuum is all the way down and header temp is a 100 degrees higher. Any ideas.
Phil
Old 12-02-2010, 07:26 PM
Gaz64's Avatar
You have an unbalanced condition bank to bank.
The bank with high vacuum is more efficient.
The bank with low vacuum has the throttles open further than necessary to maintain the idle speed you have now.
In effect, one bank is working way harder than the harder.
What tool/s are you using for carb synchrinisation?
Old 12-02-2010, 08:20 PM
dlampe's Avatar
Your going to need to get those balanced before you can do any tuning. The good news is that, with the right tools, its pretty easy.
Old 12-03-2010, 09:25 AM
Hi Thanks for all your help. Have only had the car a few weeks. It was like this when it came. I am not very mechanical but I have a friend that's a great mechanic. He has offered to help. What tools does he need to set it up. Any special instructions he needs to know.
Thanks again,
Phil
Old 12-04-2010, 07:14 AM
dlampe's Avatar
You will need a Sychometer. Thats probably spelled wrong but you get the point. I have an extra. Send me a PM or e-mail and I will send it to you. When your finished, send it back or I'll sell it to you. You mechanic will struggle without the tool.
When you get things balanced, the fun will start with the jetting!
Old 02-11-2011, 10:43 AM
RACERAL's Avatar
Cobra Make, Engine: Factory 5 mk4 445 FE
Phil, Call the they guys at Sport Auto.. the place that is in Summerfield.. I guess they are still there. I hear they can do it.
Drive that new ride up sometimes.. What do you have now.
Al Adkins
Stoneville,NC
My ex car. Sad to see it go.
http://www.ffcars.com/POM/nov2003pom.JPG
Old 02-11-2011, 01:17 PM
Don Don is offline
Phil, this vendor might know someone in your area:
http://www.inglese.com/
Old 02-11-2011, 01:27 PM
dallas_'s Avatar
or Jim Inglese can help.
http://www.jiminglese.com/index.html
