Old 11-28-2010, 02:01 PM
Xavier's Avatar
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
Default Weber 48IDA fuel pressure? 2 or 3 psi?
I can't remember, its been a while since I turned the car over. 2psi, right?
Old 11-28-2010, 04:50 PM
gsharapa's Avatar
I use to run my 48s on Boss 302 at 3 psi and also had 44s on a small block in GTD GT40 I ran at 3 psi also.
CAV GT40
Old 11-28-2010, 07:02 PM
dlampe's Avatar
Gay's right, I run just under 3 psi and it works fine. If it goes over 3, I start to have troubles.
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 11-28-2010, 07:11 PM
zrayr's Avatar
Cobra Make, Engine: Fords
I never had trouble with Weber's that were provided with 3 psi. However, if I WAS experiencing flooding issues at 3 psi, I would not hesitate to try 2.5, then even 2.0 psi to eliminate the problem.
Z.
'65 K code Mustang
'66 Galaxie 500
Old 12-23-2010, 01:12 PM
Cobra Make, Engine: Kirkham KMPS 033 FIA 289
I usually run mine Just above 1 psi but below 2psi with 48 IDA on a 289
Old 04-20-2011, 03:06 PM
Cobra Make, Engine: Unique 427 - 460 block
Default Webber PSI
I also run with 3psi, and I have never had a problem. Jeri
Old 04-20-2011, 03:31 PM
Then again it all comes down to how accurate your pressure guage is.
