Old 08-15-2011, 08:26 AM
dallas_'s Avatar
Default Webers - Which fuel pressure regulator?
I'm looking for a return style fuel pressure regulator that will allow adjustment below 3 psi and am coming up empty.
What are you guys running?
Thanks!
Old 08-15-2011, 08:46 AM
Cobra Make, Engine: SPF GT40
Why a regulator under 3 lbs.? I've run a return system with Webers set at 4 lbs. and didn't have a problem.
Old 08-17-2011, 02:33 PM
dallas_'s Avatar
I've seen guys running below 3 lbs so I figured there were regulators that would do that.
Lemans, I have that Holley regulator but wanted to run a return line back to the tank but that one is a dead head style.
Thanks for the tips on Aeromotive and Mallory.
Old 08-15-2011, 11:07 AM
priobe's Avatar
try looking at aeromotive.
They have a return style regulator
Also, try SX Performance
Old 08-15-2011, 03:05 PM
Cobra Make, Engine: kirkham stroker 48 webers
Jim Inglese put a Holley 0-3 psi regulator on my 48 IDA's. It is set at 2.5 psi
and no return line. The heat issue on my FE was not enough advance on the timing. He set it up at 38 deg. full advance. Runs really great.
Old 08-15-2011, 08:25 PM
Gaz64's Avatar
John,
How about a Mallory 4309? I run one on my car.
You could have the reg referenced to manifold vacuum.
15 inches of idle vacuum with the reg at 2psi, would give you 9-10 psi at WOT.
Or you could replace the spring with a softer rate and get 2-8ish psi instead of 3-12 psi (Mallory factory spec).
Old 08-17-2011, 03:09 PM
Earl J's Avatar
Cobra Make, Engine: GT350,289 w/48IDA Webers
Send a message via AIM to Earl J
I run 2 ½ lbs of fuel pressure as recommended by Jim Inglese as well. The low pressure Holley regulator can be had in chrome from Comp Cams-Inglese.
~Earl J
Earl J Castillo
VP NorCal Region SAAC 2012
Old 08-18-2011, 04:28 PM
Snakebit's Avatar
I run a Mallory regulator using a lighter spring set at 2 1/2 lbs. Check my pictures.
Snakebit
Old 08-19-2011, 12:08 PM
dallas_'s Avatar
Thanks Snakebit. I can't tell exactly how you have that plumbed from the photo. Can you describe how your have the lines routed?
TIA,
Old 08-19-2011, 04:33 PM
dlampe's Avatar
Kinsler will make you a preset bypass regulator at what ever pressure you want. They are some of the best at IR induction. That is the way to go. You need to be under 3 psi or your asking for trouble. I have had webers on many cars over the years and that has always served me well.
Good luck
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 08-20-2011, 06:11 AM
gsharapa's Avatar
Agree with Dean.......I've had 3 cars with webers and all ran at 2.5 fuel pressure with no issues.
CAV GT40
