| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
12-23-2011, 11:50 AM
PA
Cobra Make, Engine: ERA FIA #2124
Weber guys - Need some Main Circuit bits..
F16 e-tubes
160 Mains
225 Airs
Looking to fatten up a bit. Let me know what you have..
Thanks,
- Allen.
01-03-2012, 09:21 AM
CA
Cobra Make, Engine: GT350,289 w/48IDA Webers
Hi Allen, I have the F16 e tubes, 225 airs and the 160 main jets as spares. Do want to buy them or borrow them for tuning? Send me a PM with your contact info and your intentions. Thank you.
~Earl J
Earl J Castillo
VP NorCal Region SAAC 2012
01-03-2012, 09:24 AM
CA
Duplicate post
Earl J Castillo
Reason: Duplicate post
01-03-2012, 09:32 AM
PA
PM sent!
- Allen.
01-03-2012, 11:40 AM
FL
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
I think I have a duplicate set of 160 mains if needed that I can sell if you dont find what you are looking for
01-07-2012, 03:58 PM
QLD
Originally Posted by Fullchat289
F16 e-tubes
160 Mains
225 Airs
Thanks,
- Allen.
Allen,
Just interested in what jetting you have now, and where you need to fatten it up.
Gary
01-07-2012, 07:08 PM
PA
Hi, Gary.
Had the car to the strip in July of this year and the car pulled nicely through gears 1-3 but when I shifted into 4th, the car noticably fell flat. Pulled the plugs a bit later in the season after a hardish run and instead of a nice milk chocolate brown, I saw more of a chalky hue. Just thinking that it's fuel related..
Main Circuit is as follows and these are 44 IDF's on a 347 with Dart Pro1 heads..:
Chokes are standard 37mm
Mains 135
etubes F11
Airs 175
initial timing is set at 12 deg BTDC
- Allen.
01-09-2012, 03:10 AM
QLD
Allen,
Sounds more like the carbs are running out of fuel.
The 44 IDF comes with a 36mm choke, F11, 135 main, 175 air from factory, you say yours has 37mm choke?
Do you have a fuel pressure gauge at the carbs?
What size needle and seats?
What fuel pump?
What size fuel lines?
I ran 44s on my Blue car in my avatar, 308 cid, 38 choke, F2 e-tube, 150 main, 180 air, 2.00 needle and seat.
Gary
01-09-2012, 06:45 AM
PA
Hi, Gary.
You are correct....36 venturies.. I was going by memory
I'm running a tick over 3lbs of fuel pressure which was dialed back (sometime after the run at the strip) from a bit over 5psi upon recommendation.
My fuel pump is a Mechanical Edelbrock Performer 289-351:
Edelbrock 1725 Edelbrock Performer RPM Fuel Pumps
and needle/seats are as per stock, so 1.75.
Hose from fuel pump is a -6 AN hose, so 3/8" ID.
- Allen.
01-13-2012, 06:14 AM
QLD
Allen,
If your car pulls well up to 3rd gear then falls over, I'd say look at going up to 2.00mm in the needle and seat.
You should run a wideband O2 sensor to determine A/F ratio at full power, your problem could be the bowls are running out of fuel.
Gary
01-13-2012, 11:26 AM
PA
Thanks for that, Gary! Seems like a change that would be easy enough to try before getting into the main circuit. Guess I'll make sure the floats are set correctly while I'm in there, too.
- Allen.
