3Likes
Post By Dan Case
Post By Dan Case
Post By Dan Case
08-13-2013, 08:21 AM
MO
Cobra Make, Engine: Hurricane - FE
Weber Fuel Blocks
Does anyone recognize the brand of this weber fuel adapter?
It's made of brass, the barbs are .380" / 9.5mm, the face that mates to the carb and bolt is serrated to form a better seal with the gasket. From the measurements of the part, I am guessing they were made as metric - but not 100% sure of this.
Anyone have any experience with them? Good or Bad?
They were in a collection of stuff for weber's (thanks, Dean) and not sure of their history.
Paul
08-13-2013, 01:30 PM
NC
Cobra Make, Engine: FF 302 cam,balanced,48 IDA Webers
The center section look very much like the parts Jim Inglese makes up . I just bought a line from him with crimped ends so I don't know about the barbed shaft. What I have from him fits the 48IDAs perfectly. Check with him if you are looking to replace, Regards, Jon
09-06-2013, 12:11 AM
OK
Cobra Make, Engine: Fords
"........ It's made of brass, the barbs are .380" / 9.5mm, the face that mates to the carb and bolt is serrated to form a better seal with the gasket. ....."
I just don't like any fuel line fitting that uses those serrated edges when the fuel line slips over, as it appears these do. Nearly impossible to get the fuel line off when you need to (often on the side of the road of course). Just my opinion.
On my recent set-up from Jim I. the fittings that were smooth on the two gasket faces, and the shaft portion was straight with a bulge near the end.
Z.
'65 K code Mustang
'66 Galaxie 500
03-22-2015, 01:37 PM
FYI, I reproduce a concours level replica of the brass and steel Weber fuel inlet banjo fittings just as Shelby American Inc. modified them for use on 48IDM and 48IDA systems. These reproductions utilize a cast brass banjo (as originally supplied by Weber) with all the correct details and are silver soldered to a steel tube that has been bead rolled at one end with the correct Parker brand beading tool.
Example of the 1964+ type:
03-22-2015, 02:17 PM
another Weber related item I reproduce, to the same concours level:
03-22-2015, 05:04 PM
+1 Very authentic (the IDM version also)
DC
Dan Case
03-22-2015, 05:06 PM
+1 Very authentic details.
DC
Dan Case
03-22-2015, 05:35 PM
Thank you, Dan! Thank you also for helping out with both projects!
03-22-2015, 05:37 PM
Your welcome.
DC
Dan Case
