Like Tree5Likes
  • 3 Post By Eljaro
  • 1 Post By Gaz64
  • 1 Post By Gaz64
Old 11-22-2018, 12:32 PM
Eljaro's Avatar
Default 48IDA fuel level and float height.
I had an experience recently setting up 48IDA Webers on a 468 FE. I just took the setting and jets I had in my 482 FE and set the up on this engine.
All ran fine except the off idle was terrible and when cornering the engine would miss and stutter.
After trying all sorts of jet combinations I came to the conclusion the the float levels were incorrect.
Standard wisdom is that 5.5 to 6 mm for the float level above the carb deck is the correct adjustment.
Unfortunately carbs are inclined 10º and engine is not level but sits lower in the back,
Since the manual says that the fuel level inside the main well has to be less than 5-6mm below the nozzle bottom edge, in order to achieve that the float has to be set at 7.5mm above the carb deck.
So if you have the Weber setup with inward inclined carbs, 7.5mm is the correct float height.
cobra, Dimis and moar_carbz like this.
Old 11-22-2018, 01:08 PM
Dimis's Avatar
...and this is why I don't have an 8 stack.
A million Sundays of tinkering, I would never have been able to work that out.
I suspect this is why there are so many who swear by an 8 stack, and why so many others swear at them.
Thanks for sharing!
Old 11-22-2018, 04:46 PM
Gaz64's Avatar
How are we verifying the "true fuel level"?
With the external tube method, the level can only be correct if the carbs are vertical.
The carb main well is on the same plane as the throttle shaft, so tilting the carb up to 10 degrees should not make any difference to the fuel level in the main well.
The main well should always be at an average fuel level, since it is in the middle of the bowl. An external measuring device will be inaccurate if the carbs are canted.
Of course, like many carbs, you can experiment with float level, some of Weber's level specs have large differences.
moar_carbz likes this.
Old 10-02-2024, 03:37 PM
I realize that this is a 6 year old thread, but I'm going through setting up my Webers on a 427 with a canted manifold. I've seen posts regarding setting the level down a bit to account for the 10 degree slant. What I have noticed though, is that, depending on the installation, some have the fuel lines on the inside and some have the fuel lines running on the outside, which means that the main jets are either on the inside of the slant (inner fuel lines) or the outside of the slant (outer fuel lines). I'm thinking that this would call for different accommodations due to the slant and position of the jets. I'm guessing that the best way to get it right is to just use Paul's method of measuring from the main jet well (43mm), which would take the slant into account because you are measuring from the perspective of the main jet/emulsion tube. Is my thinking correct?
Also, does anyone know exactly where the proper fuel level is suppose to sit on the emulsion tube?
Old 10-03-2024, 03:13 AM
Gaz64's Avatar
The Main Well is in the middle of the bowl.
Weber would have designed it this way, to be less likely affected by G force or angles.
But with a choice for canted carbs, I would have the lines on the inside. The needle and seat should always be the highest point in the fuel system.
Backdraft1725 likes this.
