Pcv
Bought a “turn key” 347 stroker with a weber stack.
Issue, there is no place on the manifold to run the PCV. What now? How important is it in your eyes and has anyone out there currently or for quite sometime been running your baby with out it? Thanks |
Also interested, just installed a set of 48IDF's and noticed the same thing....
Since my car gets very little miles, I'm just going to run breathers on both sides for now until someone comes up with a better idea. |
Inglese makes a PCV port kit that will allow you to use a PCV. I don't know how it works or is configured, but would be worth looking in to. The description is on their website, on the price sheet page near the bottom of the page. John
All you need is a breather in each valve cover.
Bob |
My friend has a set of IDA's from Inglese on his 427SO, the PCV setup on his
I believe is a bunch of vacuum lines under the manifold that terminate in a single point on the top of the manifold. I don't think I want to go that route but thanks for the heads up! |
ANY PCV set-up on a webber based manifold would REQUIRE a line from each runner or the carbs would never synch/balance.
| All times are GMT -7. The time now is 03:44 PM. |
