Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 03-07-2008, 11:20 AM
Default 44 IDA vs. 48 IDF
I am looking at building a 331 with Webers. I see that the 44 IDA setup is $1,000 cheaper than the 48 IDF's. Are the 44's enough for a relatively mild 331? I am running performer RPM heads.
What kind of cam and compression ratio should I run with Webers?
Old 03-07-2008, 01:18 PM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
IMHO, the 44s may under-carburate your 331. You may end up spending the $1000 saved on jets, emulsion tubes, venturis as you attempt to tune the carbs to your engine. Common wisdom is to install 48s (IDA or IDF) on the small blocks. I've had 48IDAs on a crate 302 on my CAV GT40 for over a year and just finally gotten it to run well after fooling with jets (leaning it out) and swapping 40mm chokes for the stock 37mms.
Just my 2c
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 03-07-2008, 03:39 PM
Cobra Make, Engine: CSX4000, 427
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 03-08-2008, 12:04 AM
Rick Parker's Avatar
Hexnut72:
Are you sure you have your series Number and Venturi diameters correct. SB 48 IDA's and 44 IDF's
Rick
