Old 05-06-2008, 01:10 PM
01yelrt's Avatar
Cobra Make, Engine: SPF 2387, 427 W, Webers
Sorry, I was having trouble with my password. I finally got back into the site! The cost for the injection system is around $5600 which is pretty competitive considering what else is out there. The website for dynatek is dynatekracing.com or you can call Erik at performance engineering to get more details on his take as far as the install etc. go.
Old 05-06-2008, 05:23 PM
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
Does that price ($5,600) include the ECU and the manifold?
Old 05-06-2008, 05:47 PM
767Jockey's Avatar
I'm not well versed in injection terminology or theory, but can someone explain to me how this setup differs from the TWM setup, besides appearance? How are they different, what are the pros and cons of each type, which performs better at what RPM range and why? Thanks.
Old 05-07-2008, 09:03 AM
01yelrt's Avatar
Default what it includes
The kit does include the manifold and ecu. The website listed above should have some contact info so you could get the particulars.
Old 05-07-2008, 10:00 AM
I have a masss-flo system that I really like. I have a KC motor and I am sure with the conservative tune of the chip I am a little low on power. Probably down from 575hp to about 500ish. Still I can break the tires loose in 2nd at will :P
I do love the gas miledge and the ability to be able to just go and start the car every time with out issue :0
A properly set up carb I am sure would give me this as well. But I wouldn't know how to set it up to run this smoothly
Old 05-07-2008, 09:36 PM
Rwillia4's Avatar
767Jockey,
other than appearance there are not any fundamental differences between the two systems. Obvious things are the weber look on one and the fuel rails running in the middle of the other (TWM). Cost is a huge difference between the two TWM is 1/4 the price. Components you will need to run a FI other then the intake and horns are a fuel management system (fast XFI is what I am using), Hi pressure fuel pump, fuel pressure regulator, return fuel line, O2 sensor and a bung welded into your exhaust manifold.
What I have found very interesting is with the independent stacks a wild cam sounds very mild because there is no actual intake “air” overlap in the manifold. So idle is very smooth and not lumpy.
Old 05-09-2008, 09:57 PM
dlampe's Avatar
The Dynatech unit comes with everything but a fuel pump and regulator. There is a huge price, the dynatech is cheaper. I think that is the way I am going to go. I really like the look too.
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 05-09-2008, 10:05 PM
767Jockey's Avatar
Originally Posted by Rwillia4 View Post
767Jockey,
TWM is 1/4 the price? I have to look again, I thought it was almost twice the price of this setup. I must have looked at the wrong thing.
Old 05-09-2008, 11:17 PM
csx wnab's Avatar
Cobra Make, Engine: superformance/427 fe ford
looks great ........................but where are your red covers for when engine is not running? bad enough we run our webers without filters. least we can cover them when not running. ok sorry.........pet peeve thing..............you know, covers!
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
Old 05-12-2008, 06:31 AM
01yelrt's Avatar
Default Covers are in the trunk for the pix
I have used a black nylon cover (booties) since I had the Webers. The covers are in the trunk since the car was being setup while the pix were taken. Dynatek is actually working on a K&N filter that slips over the stack like Roush has. This will be really nice for protection and should not effect performance like the booties do on the Webers. Good call on the covers though. Thanks!
Old 05-24-2008, 07:12 AM
dlampe's Avatar
Has anyone actually installed this system on their car?
