05-01-2008, 03:59 PM
SC
302 tuning
I soldered the idle jet to the holder so that worked ok. I now have; 37mm chokes, 150 mains, 55 idle jets, 200 air correctors and F7 E tubes, 16 degrees advance. It starts and runs very well, idles good with little or no black smoke(60 idle jets smoked a good bit) but under load I get a good bit of hesitation and backfire, popping. I have the idle circuit out 1 turn, they are balanced . Any thoughts? Sounds lean
05-01-2008, 07:02 PM
GA
Not that this is the cause, but what cam are you running?
05-01-2008, 07:49 PM
SC
I have no idea Pat. The motor was built by Performance Engineering, but not for me. I do not get much reversion, so I think the cam is ok in that regard (not too much overlap)
05-02-2008, 04:23 AM
BW
Cobra Make, Engine: Sorry "just" a 68 Shelby GT500
Sounds lean to me.
When are you getting the pops - accelerating lightly or heavy ? At what RPM ?
If on light accel - IŽd check for the correct emulsion tubes or even the 3rd progression hole
If on heavy accel, probably too little pump shop - use a smaller bypass.
The one tool that made my whole Weber tuning much much easier was the addition of an Innovate Wide Band O2 Gauge - no more guessing if rich or lean.
68 GT 500
(Germany)
05-02-2008, 06:18 AM
OK
Send Dean Lampe a PM he has recently gone through all this and may be able to help. I do know that as Pat said your cam has a lot to do with the webers performance. Not to much duration (maybe around 235-250 @ .50).
Clois Harlan
"Let's roll"
"Be part of Something Good
05-04-2008, 07:31 PM
SC
I went to 155 mains, 55 idle and 205 air correctors and dropped down to 10 degrees advance(it was hard to turn over at a higher advance) and it is running much better, but still a nagging stutter at 2300 or so(very typical) I am going to order some F5 E tubes and see how it goes. I have them balanced well and it idles very good with no smoke. I also changed to new plugs, as anyone should when adjusting webers. They tend to foul quickly since most of the time we start off very rich.
05-04-2008, 10:31 PM
Can I ask at what rpm your horsepower peak occurs at?
And also how hard you can rev the engine with 37mm chokes?
