Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-23-2008, 01:09 PM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Default Fuel pressure regulator return line.
Installed my Webers. Using a Mallory fuel pressure regulator rated 3to 9 lbs. The fuel line is AN6 and the return line is AN4. Fuel pump is a Carter mechanical street pump putting out 6lbs. I can not get the pressure to adjust below 6 lbs. It should be around 3 lbs or less for Webers. Any sugestions other than tearing apart half the car to install an AN6 return line?
Snakebit
Old 06-23-2008, 02:12 PM
Gaz64's Avatar
Two things:
1. I'd run a temporary larger return into a bucket and see if it proves AN4 to be too small. Or you have a restrictive fitting somewhere.
2. Maybe your mechanical pump pulses and the bypass reg is oscillating and unable to control the bypass volume. I run a Mallory gerotor 140G/hr electric pump. Smoother fuel flow from the pump.
Gary
Old 06-30-2008, 05:23 PM
Caprimaniac's Avatar
Cobra Make, Engine: Unfortunataly ; none
My guess is: too tight return lines. I run a Aeromotive regulator and they advice 1/2" return line (corresponds to AN8..) for my application (engine front, tank rear, carb at 3 psi).
Gary have some great suggestions. Should be tried.
Old 07-03-2008, 05:50 PM
Snakebit's Avatar
Club Cobra Member
Changed to a 6AN line and used a lighter spring. Solved the problem.
Snakebit
