Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Old 06-23-2008, 02:01 PM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Hood clearance with Webers
Hello All,
I have installed 3/4 inch spacers under the webers for better cooling. I have been running the short stacks. I would like to know if you guys that have used the spacers under the carb if you ran into a problem with the hood closing.
I am noticing that my front two stacks are hitting the lower portion of the hood scoop. If I cut the hood inside the scoop it will clear the hood.
Have you guys run into this problem?
Also,
Would someone please measure the inlet of the scoop fron the tip of the top scoop to the bottom section of where it enters the engine bay.
