Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Old 01-01-2009, 10:17 PM
Rick Parker's Avatar
Default Oversize throttle Shafts
Has anyone found a source (actually purchased) oversize throttle shafts for 48IDA Webers?
Rick
Old 01-01-2009, 11:31 PM
Gaz64's Avatar
Can I ask why you want oversize shafts?
They run in a ballbearing like IDFs and DCOEs.
Gary
Old 01-01-2009, 11:44 PM
The inner bores have some wear.
Rick
Old 01-01-2009, 11:50 PM
Gaz64's Avatar
Rick, just a suggestion as I haven't come across your situation.
Could you sleeve the inner bore with sintered bronze which would act as a bearing as well as the ball bearings.
I'd say the ball bearings must also be worn if the shaft hole through the barrel is worn.
Gary
Old 01-02-2009, 12:31 AM
Banned
