Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 01-28-2009, 08:39 AM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Weber float tool
Has anyone used this Weber float tool?
I was thinking of purchasing one.
Old 01-28-2009, 03:22 PM
Haven`t used the one you show , but I used one that was very similar to it on my Porsche`s Zenith carbs . That was the only way to check float levels with the engine running .... which is the best way to find out what is going on .
Mine was easy to use and pretty much indispensable if you had Zeniths . Did some digging and I still have it .... complete with the correct graduations for the Zeniths . Got it direct from Porsche of America many years ago.
Old 01-28-2009, 05:05 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Where did you see it, how much is it, and how does it work? Can't see much from the little picture. Will it work on IDA's set at 10 degrees incline?
Old 01-28-2009, 09:36 PM
Rick Parker's Avatar
Here is another, it will work on inclined IDA's , but keep in mind the true fuel level will be shown in the canted sight glass at the same level as inside the float bowl and respective fuel wells.
http://www.biekerengineering.com/products.htm
Rick
