Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-18-2009, 11:15 PM
Cobra Make, Engine: kirkham stroker 48 webers
Default question for weber guys
anybody ever use a gunson colortune to adjust each carb? do they make them for a bb ford?
Old 08-24-2009, 03:02 AM
68gt500's Avatar
Cobra Make, Engine: Sorry "just" a 68 Shelby GT500
Send a message via Yahoo to 68gt500
You mean those see thru spark plugs??
They have been made obsolete by afordable wide band 02 Sensors.
The wide band O2 Sensor is one of the best tools you can buy to properly tune a Weber carb setup.
Mike
68 GT 500
(Germany)
Old 08-24-2009, 07:08 AM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Is there a set up for these wide band sensors to mount on a wand so they can be shoved in the side pipe, without having to weld in a bung in the header pipe?
Snakebit
Old 08-25-2009, 05:12 PM
Rick Parker's Avatar
I think it would need to be close to the collector.
Rick
Old 08-26-2009, 12:16 AM
Caprimaniac's Avatar
Cobra Make, Engine: Unfortunataly ; none
I'ts OK to run the AF in the exhaust end- pipe.
We've welded a bung in a short piece of smaller diameter tube together with a wisegrip which makes it safe to leave it behind the car......
It should be OK to put it in the sidepipes.
Old 09-02-2009, 02:54 PM
My lm 1 came with this tail pipe clamp for taking readings from the exhaust without bungs....works great.....http://www.innovatemotorsports.com/x...roductid=16141
