Go Back   Club Cobra > Club Forums > Windy City Cobra Club
Old 07-10-2007, 11:43 AM
Jerry Clayton's Avatar
Default Dyno day in St Charles
Anyone interested in a dyno day in St Charles,IL?
And if so ---When?????
Jerry
Old 07-10-2007, 03:11 PM
woody2's Avatar
Cobra Make, Engine: B&B 302ci
Maybe, how many cars min-max? How many $ per car?
Old 07-10-2007, 04:28 PM
OK----I don't have an answer as to how many cars, min/max numbers--the facility has a large service bay where some adjustments could be made while other cars were being dynoed---it takes quite a while to tie a car down properly so I'd assume that about all that could be changed while up would maybe be timing and that a carb tweeking might take a cooldown before spilling hi test on a hot motor
I also don't know if they can run the dyno on a Sunday but definitely on Saturdays
I'll find out more info and right now I was looking to see if maybe we could book 4 -6 cars for maybe 3 pulls each---what do you guys think????when we go over there to tune one of there cars it ususlly takes 5 -6 runs to dial in all the electronic computer/injector/maf stuff
Just you need your car ready for the first run and PLEASE have the gaso;ine that you drive/race it on---I have seen time after time that a car owner will change his gas brand/octane/spec gravity and it sure messes up the electronic stuff
We are going to tune a supercharged Mustang Cobra with a Whipple charger tomorrow night and I'll try to work out some specifics for a club day
Jerry
Old 07-11-2007, 08:11 PM
OK---its a Mustang eddy current model MD1750---good up to 1750 hp and 225 MPH
It takes about 45 minutes to position /tie down carn and make a couple pulls
The shop is large enough to have room to move a car off the dyno to let cool down for carb/ignition/plug checks while another car is being run--For the club they need to realize around $100/hour---they normally open at 10am but said they could/would start as early as 8am if necessary to get everybody in( probably realistic 8 - 10 cars max ) A workable minimun of around 6 cars would get us this rate and if the cars were only run a couple pulls to get a number the per car rate could drop maybe 75 if we could cycle through at 45 minutes per car.
We just got home from tuning a 2003 Mustang Cobra 4.6L 4 valve that made 419 at the wheels at 6250 rpm.
We can also use his grill to cook brats,etc or maybe do Snake and Eggs somewhere earlier
Jerry
Old 07-12-2007, 01:25 PM
Correction to the Mustang Cobra---it didn't have the Whipple---just a stock blower but with a bigger lower pulley---the Whipple was on one a few weeks ago that went a little over 500 at 6250
Jerry
