| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
07-15-2009, 06:48 AM
oh
Cobra Make, Engine: E&M FE Stroker, tremec 3550,
E-M Assembly Manual
Looking for some help please. I recently acquired an E-M early rolling chassis 1993 I am told and despirately need some engine & trans installation detail. I have an FE block, Lakewood and tremec 3550 but have no motor or trans mounts!! How far back is the engine? How deep into the chassis? Boy I could use some help here anybody?? Anybody have an early assembly manual? E-M has been extremely slow to respond even after numerous faxes, emails and a couple of phone calls. ACC out of Buffalo has been the most help but still doesn't KNOW this chassis.
07-15-2009, 07:25 AM
FL
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Can you post some pics of what you have so far.
I sent you a PM
Phil
07-15-2009, 07:26 AM
VT
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
I have a manual for a 92 E-M. Give me a day or so to see if there is any info in there. If not, I'll measure the mount distances on the lift tonight. I don't know about the Tremec as I have a top loader. The cross member will be in the same location though. Stay tuned
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
07-15-2009, 08:23 AM
Cobra Make, Engine: currently Cobra-less
I have an early E-M manual as well, could fax you the necessary pages.
Let me know if you need it
when in doubt, floor it
07-15-2009, 08:28 AM
Ill
I have a drawing someplace that shows block rear face location
07-16-2009, 08:49 PM
VT
Does this chassis have the steel mounts welded to the 4" tubes? Is the trasnsmission cross member there? The manual is junk and has no dimensions in it but, it does have motor mount part numbers and instructions on how to mount the tail shaft to the cross member. I'll get some measurements off mine tomorrow but all of these frames came with the steel mounts welded to the tubes. What do you need?
Tim
07-19-2009, 09:58 AM
Cobra Make, Engine: SPF#0760
I copied this thread over to the "All Cobra Talk" area.
You should get a larger audience there than in just the WCCC area.
Hope this helps, good luck.
Blas (WCCC Moderator)
SPFWiringDiagrams@Comcast.net
