Old 06-05-2014, 02:15 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default Valve Cover Breather gaskets?
I have a twist on breather on my Cobra Lemans valve covers, when I removed my breather to change my oil the gasket broke in several pieces.
Does any one know where I can find a replacement?.
factory five mk III roadster, 445 fe stroker
Old 06-05-2014, 02:32 PM
Rick Parker's Avatar
NAPA? Or get a piece of relatively thick gasket material and cut one out. It may be difficult to get over the locking tabs of the breather?? Perhaps cut it from sheet rubber?
Rick
Old 10-01-2021, 10:58 PM
I know a very old post but recently ran into an issue with a leaking twist in grommet on my valve cover which connects to my pcv. The valve cover hole has these tabs which require a twist in grommet. After much research the only grommet I could find was a Scott Drake C7AZ-6892. This grommet does fit but not very tightly. Had a fair amount of oil leaking around the grommet after driving the car. The valve covers do have baffles. Home Depot to the rescue with a Danco #18 O-ring. I fit over the grommet between the lower tabs and upper tabs- reinstalled and now no more leak. Just wanted to provide what worked for me as I would think others with the twist in valve cover hole may run into a similar issue.
