Go Back   Club Cobra > cobrafx
Conversation Between cobrafx and cobraleonard
Showing Visitor Messages 1 to 2 of 2
  1. cobrafx
    02-19-2015 08:48 PM - permalink
    cobrafx
    Thanks for the advice Joe. I am thinking I will do just that. It has a deep Arias oil pan and wondered how far down would be cool. Even with the crossmember should but I think it is already lower than that so once the weather warns a bit I will get back out there and look some more. I have to revisit trans mount anyway. Thanks again
    Jaime
  2. cobraleonard
    02-19-2015 03:37 PM - permalink
    cobraleonard
    I have only put BB ford in the CMC s I have built. I suggest detach the motor mts and move the motor back and down until the bottom of the oil pan is even with the front crossmember and the VCs are about an inch off the firewall. Refab the mts if needed. The way the trans xmember is made I remember putting in 1 inch spacers to raise the toploaders I used. All you can gain back and down will be major plus's in the performance. Great timing as you haven't started the headers
    Good luck
    Joe
