Go Back   Club Cobra > cscobra
Conversation Between cscobra and DanEC
Showing Visitor Messages 1 to 2 of 2
  1. DanEC
    12-02-2013 04:45 PM - permalink
    DanEC
    A couple questions on your car. On your side curtains, what did you use for weatherstripping on the bottom of them?
    On fitting the top, I understand starting in the car's center when installing the lift-a-dot grommets and working to the sides. Did you pull the top material pretty tight when installing subsequent lift-a-dot receivers of leave it a little loose. I'm curious if starting in the center might cause an excess of material at the doors after working around to the sides, if the top matrerial is pulled pretty tight.
    Thanks
    Dan
  2. DanEC
    10-04-2009 07:19 AM - permalink
    DanEC
    CSCobra - I was curious if you have taken delivery of your ERA and started on any of the bonding and riveting work. I'm still planning to bond and rivet mine also.
    Also curious if you have trial mounted the 7-1/2 inch wheels all around yet and checked it out for appearance and clearance for the undercar exhaust in the rear?
    My car is going to be a street version also and I'm still undecided on the tire/wheel combo I should go with. I'm a little concerned the 7-1/2 inch wheels in the back will shift the tire section width inwards which will cramp the exhaust space further(?) although 428Street found it to work with the ERA undercar system.
    Good luck
    Dan
