Go Back   Club Cobra > Club Forums > NW Cobra Club
Old 08-12-2005, 10:18 AM
Default mounting quickjacks?
I am changing my bumperettes to quickjacks. In looking at pictures though, it seems folks have mounted both ways (bolts on inside portion and bolts on outer edge of car). Which is correct and why?
Also, what type of nut should be used?
Old 08-12-2005, 02:31 PM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
tracyda: It boils down to whatever turns you on. The originals were mounted every which way, in or out. Just make sure they match from side to side. I've even seen originals mounted differently on the front and rear. As for nuts, the acorn type looks nice, but I've opted for nylocks. Again, whatever floats your boat.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 08-12-2005, 03:08 PM
302cobra's Avatar
Cobra Make, Engine: Modified DRB 2000, 302 Windsor
Yeah, it just comes down to personal preference. I think that inside looks best, and make sure you mount them correctly front ways as well. When you look at the car from the side (profile) they should curve away from the car. A dome top nut looks good, preferably nylock, yes.
Old 08-14-2005, 09:49 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Depends also whether it is a 289 comp/FIA car. The 289's had their jacks turned in as opposed to the 427 S/C turned out.
General rule of thumb( ) is nuts out...yet old pictures of the original cars, both 289 and 427 show them both ways and differing front to rear, even some of the museum cars are different.
As was said whatever you like best.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 08-14-2005, 09:54 PM
Thx Guys, I decided to go "nuts out" and when with SS nylocks.
I could not get the new rubber grommets (or whatever they are called) to fit in the holes in the front. Is there a trick to makeing this happen?
btw, the rears were very easy.
Old 08-15-2005, 04:37 AM
First, make sure the OD of the center between the inner and outer flanges matches or is slightly smaller than the hole. Warm the grommets by laying then in the sun, with a heat gun or sit on them, lubricate them with WD-40 or soapy water, then work each grommet into a hole. Pinch the grommet together, get one flange in, then push the rest in until it snaps into place.
Tom
Old 08-15-2005, 05:02 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
And,after you skin your shins for the umpteenth time you'll take 'em back off again LOL
Old 08-15-2005, 05:20 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
May I suggest you have them powder coated or chromed before whichever way you put them on.
Mine are showing metal from "exposure".
Old 08-15-2005, 09:16 PM
G.R.'s Avatar
Tru that's what gives the car the "patina" of use
