SUPPORT OUR SPONSOR
Old 07-20-2004, 10:39 PM
shark's Avatar
Cobra Make, Engine: Superformance Brock Coupe
Default Mechanical Fuel Pump Question
Hello Gentlemen, I have a 351W based block and I'm using the Carter mechanical pump. The in line fuel pressure gauge is now reading about 2.5 - 3 pounds. My older gauge was not liquid filled (it also started to have low readings) Several months ago I changed over to a liquid filled gauge and it was reading 4-5 pumps but not recently. I have a new fuel filter on the car.
The question: If the mechanical pump is the culprit, do they fail
completely or do they slowly fail and die giving one fuel pressure
from 5-6.5lbs (new) and then progressively lower readings untl
death.....
Thanks, Mike Sharkey
Old 07-21-2004, 06:01 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Mike,
If you have any dirt in the system it can hold the valves in the pump open and cause a low reading. Are you sure that you do not have a kink in the feed side of the line or other blockage?
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 07-23-2004, 05:36 PM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Mike,
From my "for what it's worth" department
Had two liquid filled gauges in my car. Both failed to read accurately after a month or so of use. When new, they would read 6 to 7 pounds, but when they failed they would indicate anything from zero to something short of 7 pounds.
Upgraded to an AutoMeter #2172 and have not had another problem in over two years.
Standard disclaimer..... your mileage may vary
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 07-24-2004, 09:15 PM
shark's Avatar
Default Fuel Pressure
Thanks guys, I HAD two fuel filters, one just off the gas tank and fitted with a 3 dollar special unit. I recently (a month ago) fitted a Alum. JAZ unit just afer the fuel pump. Well.. I removed the JAZ unit and my pressure now reads 7.5 to 8 lbs. (engine cold). I've gotton some feedback that the liquid gauges will sometimes read normal with a cold engine and engine compartment but will take a nosedive after the engine gets hot. It's rained some much here I haven't checked the gauge when hot yet. We'll see.
Thanks, Mike
HTML code is On
