Old 11-19-2009, 12:52 PM
vanoochka's Avatar
vanoochka vanoochka is offline
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
Originally Posted by STEPHEN BROHOLM View Post
Hi gents, I'm still struggling to get it to work.
I definitely can't see a 10 digit number, just my name, which is too long to fit into the required space.
http://www.facebook.com/stephen.broholm?ref=name
Steve.
Steve,
If your FB name (the one in the URL) is =< 10 letters you should be able to disregard all this and just type it into the cc.com field.
Mine was longer than 10 letters, and I also couldn't see the numbers. So, I used the other option described in an above post, which is to go into your FB Settings menu and change your FB name (not real name) to one that is 10 letters long.
Example: My FB URL used to read www.facebook.com/chuck.ellison. The "chuck.ellison" was too long to fit into the cc.com field, so I changed it to ecellison3, making my FB URL www.facebook.com/ecellison3. I then typed "ecellison3" into the new cc.com FB field and - as you can see - it worked like a charm.
Be aware that FB only lets you make this change one time and then the option to do so disappears from your Settings menu, so choose wisely.
I see that Ozgur helped you out while I was writing this, so never mind...
Chuck
