Old 12-03-2009, 12:51 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
I have a Halon system for my ERA. I mounted the tank in the trunk, horizontally and perpendicular to the length of the vehicle (as recommended). I routed copper line through the trunk, along the frame and into the cockpit via the engine compartment. I bought extra nozzles, and set up two sprayers under the hood and two that spray down into the footwells. The pull cable is mounted just under the dash, within reach when I'm fully belted in.
A suppression system just buys you some time to get out of the vehicle in the event of a fire. You should back it up with a good hand-held extinguisher.
Off the top of my head I cannot remember the brand. Firesafe? Safecraft? Anyhow, I have a 5 lbs bottle of Halon and a handheld extinquisher. Just seemed like a good idea with such an expensive toy.
Do a search for "halon" or "fire suppression" on www.summitracing.com. That'll get you started.
DD
Dangerous Doug
"You're kidding, right?"
