Old 12-10-2009, 04:13 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by RedBarchetta View Post
My thinking is if you use sealant for the pipe threads on a mechanical fuel pump, why wouldn't you do the same with a brake line that is also carrying a thin fluid that is under pressure?
Because sealant will make a joint more forgiving if there are tiny mechanical discrepancies... up to maybe 100 psi or so.
At the thousands of PSI in a brake system, you have it mechanically perfect or it's going to leak. You hope all it does is leak...
= Si Opus Quadratum vis, angulos praecidere noli. =
