Thread
.080 over 427 center oiler?
5
permalink
12-11-2009, 03:00 AM
RICK LAKE
I think you know the answer
Dlampe Anything is possible. If the block is filled with block crete, it will run. Need a REAL GOOD coolant system. Sonic numbers for the block are going to be the only way to see how thin the cylinder walls are. Thrust side being the most important. As far as asking some one on this forum, there are only a couple to seek out. George A. and Keith C. I don't know if Mr. Kuntz also checks in on here once in a while. You can always add more sleeves to the block. You can always sleeve a motor with a sleeve in a sleeve. We used to do this along time ago.
Rick L.
RICK LAKE
View Public Profile
Find all posts by RICK LAKE
