Old 12-19-2009, 06:02 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Superformance Related:
The brake lines run along the top of the chassis on the drivers side just below the exhaust header. I also have my fuel line relocated in this same area.
The tubing in this area can easily recieve a heat-soak from the exhaust header, heating both the tubing and its contents and occasionally causing vapor lock in the fuel line after a long ride on a hot day and spongy brakes if the brake fluid boils. This would most likely occure after parking the car for a short periods when hot. (like stopping for gas, etc)
It's easy to install a heatshield in this area before the engine is installed but a tough area to access after engine installation. Here is my solution; all installed from below the car without even taking off the tire. Tapping the 4 holes for the mounting screws was the hardest part because two of them go thru a double section of steel. Pop rivits would make for an easier installation. I think the total cost for the modification was $10 without the addition of the heat tape. Made a big difference on hot days after a long ride after stopping and restarting the car. I think the photos tell the story best.
SPFWiringDiagrams@Comcast.net
