Old 12-21-2009, 04:14 AM
Danr55's Avatar
Danr55 Danr55 is offline
Those door latches are subject to binding. I made a 1/4" aluminum backing plate to go behind mine to prevent the binding. Sometimes when the body works on the frame, the door opening can shift a bit. Try what Dan described. When you get it open, remove the cover screws and shoot some wd40 into the latch. That should provide enough lube to make it work.
Dan in Arizona
CCX3209
