  #37 (permalink)
Old 12-24-2009, 06:29 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Eljaro,
Thank you for the response.
So with the gap at the bottom of the sand this is normal. This is what I am noticing.
Driver side
cylinder 6 intake valve pushrod hits the adjustment screw with it backed all the way out.
cylinder 7 exhaust valve pushrod hits the adjustment screw with it backed all the way oout.
Passenger side
cylinder 2 intake valve pushrod hits the adjustment screw with it backed all the way out.
If I remove these pushrods at the cylinders listed above the rocker stands sit flush.
When I removed the assembly after the breakage of the rocker, all the rockers had 2 - 3 turns on the push rods.
Does this sound correct.
