Old 12-30-2009, 06:23 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Default Older EM chassis
I have an older E.M. kit that I am working on. I have talked to E.M. in the past with little sucess. I have a question for anyone that might know.
On the front of the chassis the main tubes end at the cross member. Off the the front of the end of the main tubes there are 1.5x3(+/-) square tubiing coming off of that going forward. At the end of those square tubes are some mounting plates. Some that come off the front and go towards the outside of the chassis ( I am assuming bumper or jack lift mounts) The other tabs come off and go in and back with two holes top and bottom about 2 inches apart.
I first thought radiator mount...but when I look back up the square tubing there and 2 holes with nut sets that are at an angle. I am assuming those holes are for mounting the radiator...what are the other tabs for? I will try to get a clear picture of it tonight and post it in the gallery...maybe someone out there will know...lol.
" If it wont break em loose in 3rd gear, it aint enough power "
