Old 12-30-2009, 08:19 PM
fsiewert's Avatar
fsiewert fsiewert is offline
Cobra Make, Engine: Old ('93)CMC kit, SB ford
Default Cmc
Hey Don.
Sounds like the trunk was not centered when it was bonded to the body. You will probably need to cut the trunk loose from the body, ( bonded with urethane so it will have to be cut with a sawzall or something like that) center everything on the frame and rebond it back together. I think that will also solve your trunk hinge problem......
The trunk and package tray also stabelize the couture of the body behind the cockpit.
I have a CMC too...It's not a kit car, it is a bunch of pieces that you engineer into a car.
Fred
