Old 01-09-2010, 05:54 PM
TButtrick's Avatar
TButtrick TButtrick is offline
No. Don't add to the existing panel.. It's fine. Just grab the lower part of the panel and pull it toward you a bit (toward the spindle) You'll then see that the contour is perfect. You just need to slightly bend (push) the panel from the engine bay side toward the hub. It will fit they way it should.
