Old 12-17-2001, 09:34 PM
RobMcQuarie RobMcQuarie is offline
Default Another Intake Possibility
An intake that has not been mentioned is the Blue Thunder 460 4V intake. It has the large runners that match up to the CJ size ports, and will outperform ANY of the Edelbrock intake manifold designs. It even works well with the smaller port heads and no port match, though above 4500rpm, a port match will improve power. It is in the middle of the height range at 5.25", so it won't fit some of the cars out there. Like all of the Blue Thunder products, it is superbly made. It is the manifold of choice for our 460 builds.
For a shorter installed height, Blue Thunder makes a 2-4V intake manifold, and you get to run an extra carb to boot!
