Old 02-11-2010, 07:13 PM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
If memory serves they should be black and white stripped wires from the top of the tunnel. they lead into a switch which is on the SIDE of the TKO 600.
There are two switches on the TKO
1. reverse lamp switch
2. neutral saftey switch
the factory SPF harness has a dual female T connector off the car harness that you could take 2 x 1/8" male uncovered terminals and make yourself a jumper wire to plug in.
Steve
