Old 02-27-2010, 06:27 PM
stephen low's Avatar
stephen low stephen low is offline
Nathan
The trick might be to part out all the items definitely not needed and work back from this.
I say this as items such as clips, vapour and possibly fuel lines and a raft of little ancillary bits will be there in the donor that might be able to be used. Can you re-use the fuel tank, possibly the fuel pump in another style tank if not, charcoal cannister, fuel filter just as a guide to where you can locate this and so on.
Obviously suspension, seats, main, lights, panels and so forth can go.
Also depends if you want to somewhat just plug and play with your loom or you want to pair it back to reduce the number of wires. So you need to think what you want in the cobra, dash and gauge style, etc.
If you have the space I'd suggest you don't rush the donor off necessarily.
Have fun!
slowy
