Old 03-01-2010, 11:42 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
If I would have read your details up there I would have known you were on 4 link in the rear...duhhhhh(excuse me while I put my helmet back on). The same applys for the rear as the front. Are your coilovers on the rear of the car in front of or behind the rear axle? If they behind then you will need a little heavier spring then you would if they mounted in the front.
Gene
" If it wont break em loose in 3rd gear, it aint enough power "
