Old 03-15-2010, 06:38 PM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
That joint is called a coupler. It should not have play in it. It is designed to isolate vibration through the steering column. In most cases you can replace the disk if it is worn or broken down. The only way that I could see this is if an old one was installed in the build, because they last forever!
