Old 03-26-2010, 07:21 PM
ZOERA-SC7XX's Avatar
ZOERA-SC7XX ZOERA-SC7XX is offline
Originally Posted by kgs365 View Post
should be easy ...get a salvage title from a 68-70 mustang with a big block and a top loader, change the rear end gears to get it with in 3% go through the process and change the rear end gears back to what you want and your on your way
The rear end gear in your Kirkham is probably one of the same ratios available in the Fords back in the sixties (they ranged from 2.70:1 to 4.10:1). The engine & trans can be swapped out in an afternoon. A nice running 390 w/toploader can be had for cheap (relative to your investment). You can always swap back after you get your title. Good luck.
