  #31 (permalink)
Old 03-31-2010, 04:22 AM
strictlypersonl strictlypersonl is offline
The I terminal is powered through the light whenever the ignition switch is on. In the original Ford circuit, there was also a shunt around the bulb to allow a bit more current, but we've found that the shunt is not necessary if you rev the engine over 1000 rpm at startup.
