Old 04-13-2010, 01:51 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by Caprimaniac View Post
We have royal purple here, but the cost is not 7.95 for 1 quart, but 27.82$ So, it's an very expensive oil. I'll consider it...
RS
How much?????? I smell a business oppurtunity. Anybody want to buy some bootleg RP?
Thanks, Tom.
Nice to know the (Canton) Accusump works. What I'm considering now is if I should plumb it to the rear or the front of the engine; does it matter??? (The World block have aol- gallery plugs at more than one location in the block).
Rune
With most blocks it's difficult to plumb it to the back of the engine. It can be done, though. The front of the engine (where the pump is) will lose pressure before the rear will. Then the Accusump will force oil into the system, but in reverse order. Like a wave it will try to fight any incoming oil from the pump.
If you have no other external oiling systems (cooler, remote filter), then you should put a sandwich adapter between the filter and the block. It should have one hole for the resevoir feed. That's the easiest and most reliable way to do it.
Originally Posted by Tom Wells View Post
Rune,
Don't know anything about small blocks. Having said that:
On my 460 there's a tapped hole just above the mechanical fuel pump location on the front driver's side of the block. This hole leads to the output side (gallery) of the oil pump, so that's where I put mine.
I k now very little about big blocks. But on the windsor engine, that hole is for the oil pressure gauge. It's only 1/4" NPT. Not nearly big enough for a resevoir feed. That port should be at least 1/2" NPT, fed by a -10 or -12 line.
Also on the 460, there's another place on the top rear center of the block where the oil pressure gauge fits. Some have used that spot and report it works, too, although I've not personally seen it done.
The small block doesn't have this port
I don't know of anyone using the check valve. Maybe someone else can contribute some experience.
A very big caution: don't install the Accusump piping incorrectly! It's easy to overthink this and plumb it in backwards, resulting in no oil pressure.
Hope this helps,
Tom
If you're using the resevoir with anything but the single port block adapter, you'll need the check valve. Otherwise, the oil will follow the path of least resistance, and flow right back to the pan instead of the higher pressure oil galley.
