Old 05-02-2010, 06:57 AM
undy's Avatar
undy undy is offline
Default I need a better mouse trap (gas pedal)
Below is the current Lokar pedal assembly I'm running. It's really very flimsey. With the throttle cable system and the dual carbs I'm running it tends to bend and distort with agressive foot action. It's beginning to become a real PITA as every once in a while I need to lean over and re-bend it back into shape. Unfortunately, I'm doomed to keep the cable setup so I need a stronger pedal assembly that operates in a similar fashion.
I can "modify" the pedal mount to retrofit to a different MFR's pedal assembly, need be. Any recommendations???
Too many toys?? never!
