Old 05-02-2010, 07:54 AM
ratsnst1 ratsnst1 is offline
Default I fabricated mine as well
Originally Posted by undy View Post
Below is the current Lokar pedal assembly I'm running. It's really very flimsey. With the throttle cable system and the dual carbs I'm running it tends to bend and distort with agressive foot action. It's beginning to become a real PITA as every once in a while I need to lean over and re-bend it back into shape. Unfortunately, I'm doomed to keep the cable setup so I need a stronger pedal assembly that operates in a similar fashion.
I can "modify" the pedal mount to retrofit to a different MFR's pedal assembly, need be. Any recommendations???
I used the lokar billet pedal set up, where the 2 holes that hold it in place I welded a bracket or a arm that leans out to the left side of the pedal about 2 inches with a hole at the end, so now you have it mounted with 3 bolts insread of the 2, and then it wont twist or bend on you, its very easy to do.
