Thread: Mallory Unilite
Old 05-03-2010, 04:19 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Default Mallory Unilite
Hello, you all.
I was about to bend a tab inside my distributor to get a more narrow than the factory 24 degrees of timing.
I found no tab to bend, but I found this: a small torx bolt (no. 20?) and I think, from what I could see, that I can undo this bolt and move the stop- button to get less than (or more then) the factory 24 degrees.
Is this correct? (As far as I remember, the Mallory manual doesn't say anything about this.)
I wish to run 20 degrees of timing at idle (as alot of people say is correct) and 36- 38 at 3000 (or thereabout) to make it 16- 18 degrees total.
Now I run 14 at idle and 38 at the top.
I run Webers.
Thank you.
RuneS.
